Needing Fuel hose ideas...
Old Dec 29, 2010 | 08:48 PM
Silvy6.0's Avatar
Exclamation Needing Fuel hose ideas...
I'm using a returnless fuel rail on my return fuel system. Already found a couple threads about how it works. I'm using the same corvette fuel filter. I just need to find a line or hose to run from the rail to the filter itself. It is only about 2 feet away. I am going to mount it where the fuse box used to be. Let me know if you have any ideas. I would like to use a SS line but not sure what to get.
Old Dec 29, 2010 | 09:03 PM
3zman's Avatar
Are the connections to the fuel rail the normal GM quick connect (3/8")? I had some trouble replacing the fuel lines on my 98 Camaro (the plastic ones from the fuel tank to the fuel filter). I ended up using some Aeroquip -8AN for the supply and -6AN for the return. Aeromotive makes an adaptor that goes from the GM quick connects to AN. I had been told by Pace Performance that GM no longer made the replacement lines. I had pulled the tank more than a few times and the originals were no longer safe.
Old Dec 29, 2010 | 09:10 PM
Silvy6.0's Avatar
Yeah. All GM quick connects.
