Am I missing anything?
The parts I will be putting on are:
92mm TB, 92mm intake, TrickFlow 215 heads, EPS 224/228 cam with supporting springs and pushrods, 36lb injectors, ls6 oil pump, LT headers, electric cutout past the Y-pipe, GMMG catback.
This is not including the suspension mods. I just have questions on the internals.
I am not asking for recommendations of parts, I am asking if there are any supporting mods I am missing in order to safely run these mods. Yes I know about the weak *** 4l60e and 10 bolt rear end.
Since I don't pull heads very often (hopefully once per car) I replace the lifters whenever the heads are off the block. LS7 lifters, which is the current OEM replacement, run about $130. I would also upgrade the lifter trays to the more current LS2 version.
