oil pressure ?
Old Feb 25, 2003 | 07:20 PM
rocketsled's Avatar
Default oil pressure ?
what oil pressure does the m6 cars supose to run in sixth gear? when runing about 195 to 210? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> i don't make it above 38lbs if im lucky. at idle it only runs about 21lbs is this normal? or is the oilpump about to go? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Feb 25, 2003 | 07:26 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: oil pressure ?
What type and weight of oil are you using? Coventional or Synthetic? 5W30? 10W30? How many miles on the motor? Are you sure the dipstick is reading full?
When I had a stock oil pump, I would see about 30-35 at warm/hot idle with 5W30 synthetic oil. But I have an A4 and it idled at 650rpm in park.
21 does seem knida low unless you've got a lot of miles on the motor...
Old Feb 25, 2003 | 07:30 PM
rocketsled's Avatar
10w30 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> 72,000 miles. i use synthetic. oil
<small>[ February 25, 2003, 07:33 PM: Message edited by: rocketsled ]</small>
Old Feb 25, 2003 | 07:37 PM
rocketsled's Avatar
anyone else ? could really use the help <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
<small>[ February 25, 2003, 08:30 PM: Message edited by: rocketsled ]</small>
Old Feb 26, 2003 | 11:28 PM
2001CamaroGuy's Avatar
I'm just about to hit 32,000 miles and I run Moble 1 , 10W30 oil.
850 RPM idle = about 25lbs
2000 RPM (6th gear at 80 mph) = 40lbs
4500 RPM and up = 60lbs
I noticed these pressures after I did my head/cam install and upgraded my oil system hoses (have an oil cooler and remote filters). I was not really worried but I still decided to ask around. Everyone I talked to agreed that those numbers (which you also have) are quite normal.
Here is a somewhat check list you can go through:
1) How quick does the oil pressure come up on cranking? My oil pressure is almost at 20lbs before the engine even fires off.
2) What is the warm idle pressure and does the oil pressure hold steady (not bounce around)?
3) When you go to WOT (sustained), does your oil pressure hold steady there?
4) When you return to idle, does the pressure go to where it was the last time you idled?
Hope this helps,
Chris
Old Mar 3, 2003 | 08:19 PM
rocketsled's Avatar
well i changed the oil pump this weekend and it stoped bouncing around i think the pump was on its last leg thanks for the info. dennis <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
