LS1 Rocker arm selection ??
Old Jan 8, 2011 | 01:28 PM
R6cowboy's Avatar
Default LS1 Rocker arm selection ??
Soon I'll be starting to get parts for a small build on my '00 C5 and am now trying to figure out the proper rocker arms to use. I understand the stock LS1 rocker arms are not an excellent choice for bigger cams over .550 lift. I do not know any cam geometry as of now due I'm getting a custom cam from Camshaft Innovations and I need to supply them all engine details along with rocker arm selection. I'm just looking for which rocker arms would be a good replacement over the stock LS1 rockers. Would LS6 or LS7 rockers be a better/feasible replacement? Keep in mind my Vette is a street car and due to the LS1 will have a stock shortblock, I won't be running it past 6,500 rpm. So spending the money for the best/most expensive rockers on the market is overkill.
List of valvetrain mods: (added to OP)
-PRC 220cc 5.3L stage 2.5 cnc ported heads from Texas Speed
-Replacement lifters & push rods
-Camshaft Innovations custom cam (yet to be designed)
-Double roller timing chain
List of other mods:
-LS6 Intake & TB
-80mm or 85mm MAF
-CAI
-1 3/4" LT headers & 3" X-pipe
Thanks,
Jarol
Last edited by R6cowboy; Jan 8, 2011 at 02:07 PM. Reason: Added new valvetrain components & mods
Old Jan 8, 2011 | 01:48 PM
MYSTIC-1SC's Avatar
Texas Speed offers upgraded stock units from Comp with a lot of great features.
Old Jan 8, 2011 | 01:49 PM
vettenuts's Avatar
With stock heads, upgrade your current rockers with the Comp trunnion bearing kit.
Old Jan 8, 2011 | 02:03 PM
R6cowboy's Avatar
Please see edited OP. I'm adding PRC 5.3L stage 2.5 cnc ported heads
Old Jan 8, 2011 | 02:19 PM
SOMbitch's Avatar
Yeah like vettenuts said "stock heads". Porting does nothing to affect geometry so the trunion upgraded stockers are really your best option..... Lighter and stronger than about anything else out there....
The ductile iron guides in the OEM heads are tough so you'll be fine...
Old Jan 8, 2011 | 03:30 PM
brian_rs/ss's Avatar
i've found that ws6 store offers better pricing on rockers. love tsp though. on most other things they will be cheaper.
Old Jan 8, 2011 | 04:13 PM
vettenuts's Avatar
The 5.3 is still a GM head unless they replace the guides. The GM heads have harder guides. I like the Yella Terra rockers with a bronze guide.
