C2 push rod length
Old Feb 9, 2004 | 06:26 PM
Mas280's Avatar
Default C2 push rod length
I just put a C2 MTI cam in my 99 ls1 and I am using my stock length push rods. The motor has stock heads on it, does anyone know if the stock length push rods will work or do I need the 7.4?
Mike
Old Feb 9, 2004 | 06:47 PM
2xLS1's Avatar
Mike
7.4 is stock length. Those will be fine.
Old Feb 9, 2004 | 07:50 PM
Mas280's Avatar
Thanks for the fast info.
Old Feb 9, 2004 | 08:34 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
How do you like the cam? Did you do a before and after dyno?
Old Feb 9, 2004 | 08:54 PM
Mas280's Avatar
I have the motor in a Datsun 240z. I did the cam swap before I put the motor in the car. I will be at the dyno on Fri.
Mike
Old Feb 9, 2004 | 09:48 PM
Inspector12's Avatar
TT-TECH Veteran
Glad to see you got it installed! I look foward to seeing your dyno numbers.
Jeff
Old Feb 9, 2004 | 09:52 PM
Mas280's Avatar
Thanks Inspector12 for the cam, Cam swap on the LS1 was easy. I will post my # after the Dyno.
Mike
