Ls1 finally out the top..
Old Jan 16, 2011 | 10:23 AM
97ss497's Avatar
Default Ls1 finally out the top..
Pulled it with trans only because I read the horror stories about getting all the bolts off. I had to remove the driver side motor mount that attaches to the front crossmember to get more clearance for the trans and I also had to remove the hood. If I would have pulled just the motor I wouldn't have had to do either. I had no prob getting it out with the crank pulley still attached.
Now it's off with the oil pan to see which rod bearing is spun; then it's off to AES for some machine work.
Attached Thumbnails Ls1 finally out the top..-dsc00216.jpg   Ls1 finally out the top..-dsc00217.jpg
Old Jan 16, 2011 | 10:39 AM
97ss497's Avatar
BTW I used the Happy Hooker from TPS; it worked awesome...
Old Jan 19, 2011 | 02:11 AM
BennyB's Avatar
fun, fun... nice work man. When its time i plan on doing mine this way also
Old Jan 19, 2011 | 08:05 AM
Steve Gunn's Avatar
Nice, you were smart to pull them out together. That would have saved me several hours.
Old Jan 19, 2011 | 12:37 PM
jetaws6's Avatar
what does that happy hooker attach to
Old Jan 19, 2011 | 01:59 PM
99 Blue Bird's Avatar
the top of the block were the valley cover bolts down. it worked great for me aswell
