Best Street Cam
Old Feb 11, 2011 | 07:55 AM
  #41
zz4camaro1980's Avatar
228/232- My car drives like stock, has a nice flat torque curve and pulls great right up to 6500 (power does not 'fall off' at all). This is how the car should have come from the factory in my opinion.
Old Feb 11, 2011 | 08:05 AM
  #42
disc0monkey's Avatar
Originally Posted by Midnight00SS
wow thats in insane gain! very nice, wut is ur ext and int lift?
ill step in here til turk can give u his response. the lobes are pretty "lazy" as they geared to not kill the springs and makes it easy to maintain stability of the valvetrain with popular/cost efficient components. therefore they shouldn't be too much more than .600 but still give lift where and when needed to make great power.
Old Feb 11, 2011 | 08:06 AM
  #43
bayer-z28's Avatar
Thunder Racing has a new line of Cams out. Marketing says they're good all around. Just my $0.02.
I've always liked their grinds. Or PM PatG and tell him what you are looking for.
http://www.thunderracing.com/shop-by...hafts_972.html
Old Feb 11, 2011 | 08:16 AM
  #44
bayer-z28, theres no surprise TR released cams of that category as most of these companies are updating their 22X duration cams from the great results had from the now dated 224 cams. hint, hint guys this is no coincidence. this duration range is a sweet spot for an bolton 3400+lbs street/strip ls1
Old Feb 11, 2011 | 08:19 AM
  #45
bayer-z28's Avatar
I've got a PatG custom and it has a nice curve (From what I can see. TSP chopped the graph) ... Flat tq curve and carries to 6700 witout falling off. Great street manners. I've always said that those HUGE cams for a h/c bolt on LS1 were overkill and it seems like the more mild cams are coming back strong.
Old Feb 11, 2011 | 09:41 AM
  #46
*02WS6TURK*'s Avatar
226/230 .598/.600 114
As streetable as it is, I kinda wish I had gone with something in the 230/234 range. Overall I am happy with the gains.
Old Feb 11, 2011 | 12:39 PM
  #47
Midnight00SS's Avatar
Very nice results guys now i just gotta pick a cam that i want, so much to chose from lol
Old Feb 11, 2011 | 12:43 PM
  #48
brians91formula's Avatar
Originally Posted by Rise of the Phoenix
The options are unlimited my friend. I would say something along the lines of 228/232 110 lsa would give you a nice lope, and still give you nice power under the curve.
Originally Posted by *02WS6TURK*
I'm running a EPS 226/230. Very streetable and makes great power all over the board. Contact Patrick G and have him spec you a cam. With a M6, a 226/230 on a 112 LSA would net you good power under the curve, have a nice lope and be a beast on the street. A lot of it's in the tune as well so be sure you get yourself a dyno tune afterward.
^ both great cams.
I made 402/378 with a 227/233 cam.
Old Feb 11, 2011 | 07:21 PM
  #49
James Linder's Avatar
Katech LS1 Torquer - same as Z06 with smaller LSA and use 1.8 ratio rocker arms to make it a little more radical on lift. You will be amazed at drivability, torque, and it is relatively easy to tune. Talk to Katech if you want a cam that is awesome without going with the long duration cams that are more difficult to tune.
Old Feb 12, 2011 | 11:57 AM
  #50
Originally Posted by brians91formula
^ both great cams.
that sounds good too, i got alot choosing to do lol
Old Feb 20, 2011 | 12:41 AM
  #51
Spring Time
