Question about installing stock crank pulley?
Old Jan 25, 2011 | 05:41 PM
bmf5150's Avatar
Default Question about installing stock crank pulley?
I have a 97 corvette ls1 that I'm putting the stock pulley back on the crank!how do I know if it's on all the way,will the inner edge of pulley sit flush with the end of the crank??
Old Jan 25, 2011 | 07:00 PM
LS1MCSS's Avatar
Stick the water pump on and see if the pulley grooves and belt marks on the pump line up.
Old Jan 25, 2011 | 07:32 PM
bmf5150's Avatar
I would except my water pump and pulley have never been used!
Old Jan 26, 2011 | 04:25 AM
vettenuts's Avatar
There is a procedure that should be followed and part of it is the measurement from the edge of the pulley hub to the end of the crank snout. Don't use a bolt to pull it on.
I posted the service manual procedure recently in post #7 of this thread: Link
Old Jan 26, 2011 | 12:47 PM
bmf5150's Avatar
Thank you!
