Just ordered a cam
Old Feb 11, 2004 | 12:36 PM
BLKWS6's Avatar
well you would be better off going with 918s and a 224 cam being your first ls1 and cam. IMHO.....
Old Feb 11, 2004 | 12:41 PM
bigoneZ28's Avatar
Wink
Originally Posted by xphantomws6x
And go back to school ... I think your worse then Cudah.
See what happens when the mods let the STF out of the street racing section?
you're (you are)
He should have researched this some more
Old Feb 11, 2004 | 12:44 PM
JoSeY's Avatar
why the shorter PR's??!! I had 7.400's on my stg 2 mti heads with their X1 cam....I did do the SMART THING and run Rev Dual springs...any lift above .550 and not having duals ur asking for A LOT of trouble. AT LEAST get the new Manley Duals that fit in the stock spring space. I went w/the bigger Rev Duals that required machining......
Go Cheap.....blow up...do it right...win races...my moto
Old Feb 11, 2004 | 03:18 PM
x phantom x's Avatar
STF veteran / 10 second club
I agree ... I don't think you're going to be happy with such a large cam as your cherry popper.
Originally Posted by bigoneZ28
you're (you are)
haha, I'm well aware, just too lazy to use apost. most of the time.
Old Feb 11, 2004 | 10:57 PM
johnboy's Avatar
Originally Posted by ls1jimmy
i did the research and did not come up with what cam i would like then i ask them thay said it would be a good cam with the valve springs i have delt with a lt1 for years and this is my first ls1
jimmy are you old enough to have a drivers license??
Old Feb 12, 2004 | 01:14 AM
Robzilla's Avatar
first off, you guys are dicks, but its funny though
the 918s are good up to 600 or 610 lift(something around there) and many people have used them with big cams so it will work, but personally i wouldn't do anything but dual springs
and Josey which Rev Duals do you have because I'm almost positive the 1116s don't require machining
Rob
Old Feb 12, 2004 | 09:10 AM
ls1jimmy's Avatar
i ok dick heads i just ask a ? that i allready new and the shop told me to put the springs in and change them in 6 mo so that what i am doing if it brakes i will get a hole new motor . i
Old Feb 12, 2004 | 09:22 AM
ROTFL!!! What an idiot.
Yeah you're right ... go with the springs that will cost you 30 dollars less, then just replace your engine when you break it .... good call.
Old Feb 12, 2004 | 11:56 AM
ls1jimmy's Avatar
your an idiot the car allready has 80k on it i need a new motor my girl will not let me have 1 tell this one brakes. so think i am real smart and the shop told me that it would cost 300 more for better springs
Old Feb 12, 2004 | 12:11 PM
Kens_02SS's Avatar
Old Feb 12, 2004 | 12:27 PM
bigoneZ28's Avatar
This thread is a f***king riot
Old Feb 12, 2004 | 12:35 PM
  #32
35th SS's Avatar
man you guys are hilarious.give the guy a break.
Old Feb 12, 2004 | 12:45 PM
  #33
Kens_02SS's Avatar
He should have posted this in the "newbie" section
Old Feb 12, 2004 | 06:06 PM
  #34
1) 80,000 miles ... yeah you're probably right, the engine is almost shot.
2) Your g/f won't let you have a new motor?
3) "so think i am real smart " - Yep, you sure do sound quite intelligent...
4) Another reason you are an idiot is because you continue believing a shop that is obviously ripping you off over and over again.
www.thunderracing.com - do yourself a favor and go check out how much dual springs cost.
Old Feb 12, 2004 | 06:39 PM
  #35
That's what we're here for ... and no, I will not give that guy a break.
Old Feb 12, 2004 | 06:41 PM
  #36
JoSeY's Avatar
80K miles?? ****...my car is making in the 440 range with over 110,000....just take care of them and they'll be fine.
Old Feb 12, 2004 | 06:45 PM
  #37
SouthFL.02.SS's Avatar
!LS1 11 Second Club
This is what happens when the Street Racing and Kills gang roams over to the Internals. Advice with smacktalk.
Definately do not pair Comp 918's with a .600 lift cam. (oh crap, I have 918's with a .598/.595 cam ). Anyhow, definately get the dual springs.
Old Feb 12, 2004 | 06:48 PM
  #38
I'm over here all the time ... it's just you don't normally find people like this over here ... most of the people that ask questions in this section usually want to hear the answers/opinions of the people on the board .... not just state how they already know everything, when in fact they are doing it wrong.
Old Feb 12, 2004 | 06:50 PM
  #39
!LS1 11 Second Club
I know.
Old Feb 12, 2004 | 07:21 PM
  #40
98'MidnightBlueBird''s Avatar
