Rod side clearance
Old Jan 26, 2011 | 09:56 AM
formula89utah's Avatar
Default Rod side clearance
I have an LQ9 block with LS2 pistons and Scat 4340 rods. The side clearance is .022 and the spec call for .005-.020. Is the extra .002 going to cause a problem?
Old Jan 26, 2011 | 12:57 PM
RARON455's Avatar
Well,,,they list min and max specs for a reason, although .002 is not a great amount, your measurement shows excessive clearance. Will it be ok, or a problem, idk,,one of the possible effects could be noise from the lower end, possible premature bearing failure. are you certain about your measurement? or you could never have an issue. personally I would not chance it and call scat about those rods, see what they have to say.
Old Jan 26, 2011 | 07:32 PM
JPH's Avatar
JPH
Are they ALL .022?
Old Jan 27, 2011 | 11:58 AM
The side clearance is .022 on all. Big end width is .946 on all stock rod and .941 on all Scat rods.
