preload
Old Jan 28, 2011 | 11:04 AM
2000RDT/A's Avatar
Default preload
hey guys. i bought a 228r and installed it with ls7 lifters, 7.35 pushrods, in use with prc 5.3l 2.5 heads with dual springs. installing the rocker arms. preload is at .100 is this where it should be? thanks
Old Jan 28, 2011 | 01:52 PM
2000RDT/A's Avatar
anyone? ive been searching. finding from .05-.08 to .06-.09 to .06-.1 my preload right now is .1. ive heard this will be a little quieter. ive heard the opposite. regardless of that it seems a little high. and this is with the 7.35 pushrods. any help?
Old Jan 28, 2011 | 05:36 PM
Darkman's Avatar
Your preload of 0.100 is higher than the 0.060 to 0.080 range usually associated with OEM lifters, but, as your own research revealed it is not higher than some run. Is your valve train noisy at that preload?
Old Jan 28, 2011 | 10:21 PM
RARON455's Avatar
Originally Posted by darkman
your preload of 0.100 is higher than the 0.060 to 0.080 range usually associated with oem lifters, but, as your own research revealed it is not higher than some run. Is your valve train noisy at that preload?
yup.....
Old Jan 31, 2011 | 12:23 PM
2000RDT/A's Avatar
i havent finished putting the motor together yet. did a rebuild from a spun bearing but are just wrapping up the top end. so no the motor hasnt been started yet
Old Jan 31, 2011 | 12:26 PM
Greekey's Avatar
Many say thats to high of a preload. Many will shoot for .075 to .080.
Old Feb 1, 2011 | 04:16 AM
vettenuts's Avatar
The times I have measured stock it was near 0.100". GM does have a specification for that lifter but I can't find the data sheet.
