Pushrod Length
Old Jan 30, 2011 | 11:55 AM
VandykeT/A's Avatar
Default Pushrod Length
Ok I'm about to install PRC 215s and a MS4 cam. I have a Comp Cams pushrod checker but I'm not sure how to go about using it. I've searched this but can't make sense of anything. I'll be running LS7 lifters. Can someone explain how I need to go about measuring for my pushrods. Thanks
Old Jan 30, 2011 | 06:54 PM
Duke_Z28's Avatar
It can be a bit confusing, but I recently did research into this as well, one newb to another...
https://ls1tech.com/forums/generatio...-method-s.html
Old Jan 30, 2011 | 07:45 PM
vettenuts's Avatar
Each turn of the pushrod is 0.050". When fully closed, it is 6.800". This is pushrod "gauge length" so you can't measure it directly as the pushrod length is actually based on the length between the ball ends where the ball end measures 0.140" in diameter. Assuming you are using stock rockers or a non-adjustable rocker with a correctly established wipe pattern.
1. Open the adjustable pushrod to the same length as your stock pushrods
2. Close it down two turns
3. Put your rocker rail on the head
4. Make sure you cylinder (typically #1) is at top dead center on the firing stroke so both valves would be closed
5. Put the pushrod in place on the intake valve and make sure it is in the lifter cup
6. Install the rocker and snug down the bolt (don't need to torque, just make sure it is snug)
7. Lift rocker tip up and down, if it "ticks" the pushrod is too short. If you can't easily move the rocker the pushrod is too long.
8. You can try and adjust the pushrod in place buy my fingers are too fat so I end up pulling the rocker and adjusting the pushrod length. Go either shorter or longer 1/2 turn and try again.
9. You are trying to get to the point where the lifter doesn't "tick tick" with the pushrod in place nor is the rocker snug. When you get the pushrod length such that you just barely get rid of the "tick tick", you have found "zero lash".
10. When you have found zero lash, carefully remove the rocker and pushrod without rotating the pushrod.
11. Tighten the pushrod until it is fully closed counting the turns as you go.
To figure out your pushrod length you do the following. Lets assume it took 10-1/2 turns to close the pushrod down to its shortest length after you reached zero lash. Each turn is 0.050".
Your length is then: 6.800" (fully closed length) + 10.5 X 0.050" (number of turns times the length change per turn) = pushrod length minus preload. So for this case:
6.800 +10.5 X 0.050 = 7.325"
This is the length you measured to zero lash without any lifter preload. Now lets say you want to have 0.075" lifter preload, you add that to the measured number and you end up with 7.400" pushrods.
Now repeat for the exhaust valve to verify the length. If you have something like Yella Terra's, it is the same procedure but you must snug down the rocker pair rather than the single rocker.
Old Feb 1, 2011 | 07:57 PM
2000ls1tranz's Avatar
hey keep us updated with what u come up with i am very interested to see if our measurements are the same i also have the ms4 cam an ls7 lifters and prc 215 heads what cc are urs??? mine are 60cc ....on stock rockers an gm head gaskets
Old Feb 2, 2011 | 05:40 AM
VandykeT/A's Avatar
Sounds like we've got the same set up. 60cc and I've got the MLS gaskets.
Old Feb 6, 2011 | 01:01 AM
u measure yet???
Old Feb 6, 2011 | 06:02 PM
VandykeT/A's Avatar
I haven't measured yet a buddy of mine is doing the install for me and he hasn't got that far yet but when he does i'll let you know. Thanks
