7.30 Pushrods sound right?
Old Feb 1, 2011 | 02:12 PM
Greekey's Avatar
Default 7.30 Pushrods sound right?
I'm getting ready to put the valve train back together, and thought I would measure for pushrod length again just to be safe. I installed the adjustable pushrod making sure it was on the base circle of the camshaft and not touching the rocker. I torqued the rocker down to 22ft/lbs and then started adjusting the pushrod until I reached zero lash. I removed the rocker and pushrod making sure I did not turn the push rod while removing it. I am just shy of 9 full turns on the pushrod until it is fully closed. I am actually at 8 3/4 of turns until it is closed. Doing the math, I divided .050 by 4 and got .125 so 3/4 of a turn would put me at .375. So the real number of turns is 8.375 until it is closed. Doing the math, 8.375 x 0.050 + 6.800 would give me 7.220. Doesnt this sound odd? And doesnt it sound odd thats with zero lifter preload? I was planning on running a 0.075 preload and that would give me an overall length of 7.295. WTF??? My ls6 heads were milled .030, running ls7 lifters, and a Gm mls gasket.
Old Feb 1, 2011 | 02:18 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That's bad math It is 8.75 turns x .050" per turn = .4375 + 6.800" base length = 7.2375...that's your zero lash length. 7.300" would put you at .0625" of preload.
The thing that concerns me is that this week you've got a different zero lash length than last week....I'd do it again, and hope you repeat either the length from last week or this week.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 1, 2011 | 02:19 PM
Greekey's Avatar
Crap I meant 8.75 oops.
Old Feb 1, 2011 | 02:30 PM
Greekey's Avatar
Okay since its a 7.2375 with no preload:
7.2375 with desired preload lengths:
.075 preload=7.3125 pushrod
.080 preload=7.3175 pushrod
.085 preload=7.3225 Pushrod
.090 preload=7.3275 Pushrod
So Ill be fine running a 7.325 pushrod correct? Do these numbers sound right? I actually checked and checked and got these results over and over again.
Old Feb 1, 2011 | 02:32 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I've come up with 7.300-7.325 on cars with milled LS6 heads, thin gaskets, and LS7 lifters in the past
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 1, 2011 | 02:33 PM
Greekey's Avatar
And thats with preload correct?
Old Feb 1, 2011 | 02:40 PM
With your measurement, and using readily available pushrod lengths, here are the correlating preload values.
7.300" = 0.0625" preload
7.325" = 0.0875" preload
7.350" = 0.1125" preload
__________________
Old Feb 1, 2011 | 02:47 PM
Greekey's Avatar
Thanks matt.
Old Feb 1, 2011 | 03:02 PM
Yes, I am talking pushrod length
__________________
Old Feb 2, 2011 | 09:36 PM
blackmagicturbo's Avatar
Just outta curiosity ,,what is your retainer to seal clearance at max lift with 7.325 pushrod ?
