Ls1 h/c help
Old Feb 3, 2011 | 08:26 PM
bandito's Avatar
Default Ls1 h/c help
Ok so I'M trying to find a good head and cam package for a daily driver stock cubed ls1. So far I have headers, ls6 intake, 3.73 rear and an A4 without a torque converter yet. Waiting for info. I looked at the 227 heads from prc and the tf215 not sure which is better.... But I would like the 228r cam or ms3. Looking for an 11 second setup any other ideas? Idc about it being expensive.
Old Feb 3, 2011 | 08:29 PM
Whiteaw57's Avatar
I would call texas speed and and ask the same question. You have very specific needs that im sure they could handle. If your wanting a daily driver the 228 with some nice heads would be a better bet than the ms3. good luck with the build
Old Feb 4, 2011 | 07:21 PM
bandito's Avatar
Trying to make time to give them a call. Work don't let me. So what all would I need for a complete h/c swap? Oil pump timing set and tune? If I can get a good deal I'm sure I go by in April to get it all installed I just ordered a strange Dana rear so I feel like I need to beat my friend and his terminator and other turbo mustang
Old Feb 5, 2011 | 07:11 PM
bandito's Avatar
Any one wanna help?
Old Feb 5, 2011 | 07:47 PM
garygnu's Avatar
TSP heads are on sale.if you are on a budget get the ls6 st 1 heads.if you can afford more look at the prc 215 heads with iron guides ,for a stock cube motor.get a torquer v2 cam.get the trunnion upgrade bearings for your stock rocker arms,and a ls2 timing chain.TSP has a head/cam install kit,and if you car has higher mileage consider a oil pump from them also.if you have a A4 get a 3500rpm+ stall converter.you will need bigger injectors..find a good local tuner .you will need some good suspension pieces and DR to hook up .
Old Feb 5, 2011 | 08:54 PM
Mazzenger's Avatar
I would consider TFS 220 as cast, TSP PRC, and AI heads. I like both 228 and MS3.
My MS3 woke up after a higher stall and 3:73s were added. I would also consider maybe having somebody spec you a custom cam after you choose your heads. Make your combo work together.
Old Feb 9, 2011 | 09:59 PM
bandito's Avatar
How good are ther 227 prc heads? I want to go all out on the ls1 for a dd and put the heads on a 402 later
