5.3 heads with offset rocker arms
Old Feb 6, 2011 | 01:38 PM
trans_am7935's Avatar
Default 5.3 heads with offset rocker arms
so i read somewhere that the 5.3 head uses offset rockerarms. is this true? i am about to order me some PRC 5.3 stage 2.5 heads and i need to know if i can use my stock LS1 rocker arms. when i called TSP and told them i was planning on getting these heads they didnt mention it so i assumed i didnt need the offset rockers, also it is not on their website. so do i need offset ones for these heads or can i use my stock LS1 rockers safely on the PRC aftermarket heads?
Old Feb 6, 2011 | 02:08 PM
RARON455's Avatar
I have those heads and the are not offset,,and yes you just use your rockers and pedastals no problem. Now you may need different pushrods,,better measure to be sure.
Old Feb 6, 2011 | 02:10 PM
LilJayV10's Avatar
The LS3 uses offset rocker arms
Old Feb 6, 2011 | 02:49 PM
good, how do you like those heads btw, and what head gasket did you go with? i was looking at the MLS .040 to make close to 11:1 compression
now this i didnt know....silly LS3, should have been a simple LS1...
