LS1 combustion chamber/piston question
Old Feb 10, 2011 | 10:57 AM
jgebhardt's Avatar
Default LS1 combustion chamber/piston question
I am building a new LS1 for my 98 Trans Am. I am using Trick Flow GenX 220 heads with a 64cc combustion chamber. I want the compression to be at or a little above 11:1. What type piston do I need? Dished, flat or dome? Also what type are the stock ones and what is the combustion chamber size on the stock heads? Any help or advice would be appreciated.
Old Feb 10, 2011 | 01:37 PM
Jon@HKE's Avatar
Closed ex-Sponsor Account
With the stock (flat top) pistons you will be around 10.7:1 with .052 head gasket. You need a slight dome or mill the heads to achieve the compression you want.
The stock heads are 66cc~.
Old Feb 10, 2011 | 02:32 PM
jgebhardt's Avatar
Default ??
the heads I am loong at are 64cc being 2cc smaller wouldn't get me there?
Old Feb 12, 2011 | 06:39 PM
jgebhardt's Avatar
Still looking for more info on this.
Old Feb 12, 2011 | 08:50 PM
trans_am7935's Avatar
for example i am using PRC 5.3 heads with a 1cc mill for a 61cc chamber and the .040 MLS head gasket, i am gonna be just at 11:1 with the stock flat top pistons
