Iron to Alum CI questions
2. When stroking an LS2 it comes out to a 402 and when stroking a lq9 it usually goes to a 408. IF question number 1 is true why is this? If question 1 is not possible then I guess I sorta understand.
LS2 is 364 Ci the Lq9/4 is 364CI
If anyone has time to explain I would really appreciate it.
But the internals from an iron 408 WILL NOT fit an aluminum block because you can't (safely at least) bore it out to accept the 4.030 pistons.
