car shutting off
Whenever I have the ac or heater on in the car and go to stop at a light the car can sometimes just shut off on me. Also can shut off if I turn the steering wheel all the way to the right or left the rpms will dip then just die. Cold starts the car likes to warm up so I rev it a little till the rpms start to settle but if its not warmed up sufficently while driving the rpms may start to dip then the car will shut off
Car likes to buck or jerk at low speeds below 40.
This seems like its all a problem with the idle control somewhere but wanted to know if anyone else has anything similar.
Kinda worried driving the car anywhere too far since the car won't seem to idle and coast too well anywhere so I try and just downshift as much as I can to keep it going or else I may rev it a bit to keep it up. This problem doesn't happen everytime I drive but every other day or so.
Mods: heads/cam full exhaust long tubes/ fast intake/
FWIW, since you aren't getting any codes, it sounds more like it's a tune problem. It might be a good idea to have someone take a look at it with HP Tuners or EFI Live. There must be some good shops down there...
