ms4 cam in a lq9 clearance issues?
Old Feb 17, 2011 | 03:02 PM
jjbiggers2's Avatar
Default ms4 cam in a lq9 clearance issues?
ok so i got me a lq9 stock 317 heads and gaskets. Will i need to fly cut the pistons for my ms4 cam out of my ls1. It was fine in the ls1 no issues. I know i should check it just trying get an idea before i do it.
Old Feb 17, 2011 | 03:41 PM
BOBS99SS's Avatar
Captain Double Post
I don't think you will have to,I will be doing this swap soon and I'm gonna put my ms4 in the lq9,call texas speed,I'm sure your ok but I always check clearance,
Old Feb 17, 2011 | 03:44 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
It will clear with about the same clearance as you had on the stock LS1 long-block. We definitely always recommend checking piston to valve clearance to ensure you are good though....if your timing set is off on a cam that big by just a few degrees, you can end up with piston to valve contact!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 17, 2011 | 03:46 PM
09camaro383's Avatar
you dont need to fly with stock 317 heads but like matt said timing has to bee dead on!!
Old Feb 17, 2011 | 03:47 PM
BOBS99SS's Avatar
Captain Double Post
Let me know what ya find out,also what ya get for numbers
Old Feb 17, 2011 | 03:58 PM
jjbiggers2's Avatar
Ok thanks for the quick responces guys. I will check it to make sure.
