Head Cleaning
Old Feb 19, 2011 | 06:14 PM
CNTLSE 1's Avatar
Default Head Cleaning
I just pulled the ported LS6's off to replace with 227's so I am going to sell the LS6's. Whats the best way to clean these heads up before I sell them?
Old Feb 19, 2011 | 06:49 PM
earmuffs's Avatar
media blast, or solvent tank
Old Feb 19, 2011 | 06:52 PM
CNTLSE 1's Avatar
I'm not going to disassemble them
Old Feb 19, 2011 | 07:16 PM
earmuffs's Avatar
then there isnt a lot you can do. most of the dirt is going to be under the springs and valves
Old Feb 19, 2011 | 07:18 PM
garygnu's Avatar
use some degreaser or gas and a scott brite pads for the chambers..to clean out the ports ,face the port up and fill with solvent and let soak for a day or 2.use a firm tooth brush to remove the carbon.do a finally rinse with carb cleaner.
Old Feb 19, 2011 | 09:24 PM
CNTLSE 1's Avatar
sounds good thanks. There's only a couple thousand miles on them just want to get the surface junk off
