depressing spring depressor
Old Feb 14, 2004 | 05:26 PM
TnTrk53's Avatar
Default depressing spring depressor
Cam swap done no problem.
spent an hour or so trying to get universal spring depressor to pull down enough to remove locks...no luck. Cam has .564 lift so stock springs will bind,I think.More racing has tool that is suppose to work for about $130.,I'll just be using it once. I can't be the first to arrive at this point ,so someone has a tool out there for sale cheap. Is it you? PM me if you do.
Thanks, Jim
This may get moved to the want ads but it seemed subject related.
Old Feb 14, 2004 | 06:46 PM
foff667's Avatar
LS1TECH Sponsor
check the tools section duh or ask fer larry
Old Feb 14, 2004 | 06:50 PM
98SS Blackattack's Avatar
BINGO
Old Feb 14, 2004 | 10:39 PM
jrp's Avatar
jrp
SN95 Director
i bought both kinds of tools from autozone; the lever tool and cut off the handle and the other kind. the lever cut off tool is the one that worked best. get the larry one as the autozone ones are a piece of ****. the larry tool comes with a re-inforced bolt and nut which you'll need, i broke a water pump bolt on mine using the autozone **** when you compress the spring just tap the retainer a bit the it should loosen up the locks so you can remove them with a pen magnet.
with the right tool a spring swap is easy, with the wrong tool
Old Feb 15, 2004 | 09:21 AM
TnTrk53's Avatar
Thanks Guys, I didn't even no the tool section existed is larry a brand name?
Being cheap doesn't make me a mechanic, it just makes me try to be.
Old Feb 15, 2004 | 09:44 AM
TnTrk53's Avatar
Found larry, thanks
