coolant in intake????
Old Mar 2, 2011 | 11:53 AM
dlross's Avatar
Default coolant in intake????
i been losing coolant. had the system pressurized no leaks at all. so i started to tear it apart and there was coolant in the intake behind the throttle body. i thought maybe bad intake gaskets. but after i took the intake off all the "orings" for the intake looked fine. i just want some second opinions before i go a tear all the way to the heads. thanks
Old Mar 2, 2011 | 12:22 PM
dlross's Avatar
bump....
Old Mar 2, 2011 | 01:03 PM
dlross's Avatar
input anyone???????
Old Mar 2, 2011 | 05:21 PM
garygnu's Avatar
maybe a cracked head and coolant is be inhaled by the pcv system.was it alot of coolant or small puddle?look at your plugs and do a compression check also.you mite have some moister condensation and its getting in the intake.
Old Mar 2, 2011 | 05:58 PM
O2Form's Avatar
Coolant goes through the throttle body, its probably cracked etc.....i hope you didn't tear the intake and heads off yet.
Old Mar 2, 2011 | 07:54 PM
SOMbitch's Avatar
^^^^^^^Yeah and you can bypass with this mod >>>> http://www.ls1howto.com/index.php?article=13
Old Mar 2, 2011 | 08:00 PM
dlross's Avatar
i have the bypass mod done all ready. i figured that it was just moister in the intake but i have a bad head gasket. thats the only place i can think that the coolant is going. is not onthe floor
