need help
Old Mar 4, 2011 | 01:04 AM
super mario's Avatar
Default need help
I have a lq4 and torqued everything down and I bought a standalone harness and I'm tryin to crank it up but it won't turn over...any suggestions?
It tries to turn over but does not want to...it moves little by little
Old Mar 4, 2011 | 01:22 AM
Greekey's Avatar
Are u getting battery power? Have u checked fuel pressure? Have you checked for spark?
Old Mar 4, 2011 | 01:26 AM
jalper's Avatar
Restricted User
sounds like a starter issue, does not sound like a stand alone issue.
Old Mar 4, 2011 | 01:35 AM
I have it on a test stand and I'm just trying to make sure it will start before anything..my starter is brand new and its clicking and barely moving the fly wheel. But I have a battery charger on the battery
Old Mar 4, 2011 | 01:57 AM
68ss70z28's Avatar
Default Starting
Do you have a good ground, and did you check the voltage at the starter with a digital voltmeter. And the voltage drop at the battery when cranking.
