engine light on help guys
Old Mar 5, 2011 | 08:44 AM
DPRock's Avatar
Default engine light on help guys
P0300 Misfire detected
P0412 air switching valve A problem
P0418 air pump relay control circuit problem
Miss history 1_____2
Miss history 2_____982
Miss history 3_____0
Miss history 4_____0
Miss history 5_____147
Miss history 6_____0
Miss history 7_____4679
Miss history 8_____0
The car is bone stock
Old Mar 6, 2011 | 01:09 AM
cowboysfan's Avatar
I'm guessing your car is an Fbody? check the plugs or replace them if you have not... check the wires!
air pump issue I would check connections...
