Need an adjustable timing set
Old Mar 5, 2011 | 02:26 PM
H'ville TA's Avatar
Default Need an adjustable timing set
In the process of degree-ing my 230/230 cam and need an adjustable timing set. Looking to draw on y'alls experience to make the best choice. Already upgraded to the Melling high volume and just looking for something adjustable to fit behind it (or with minimum shimming). Any suggestions? Thanks
Old Mar 5, 2011 | 02:40 PM
outkast6991's Avatar
rollmaster double here. came with shims and no clearance issues with the front cover (stock pump)
Old Mar 5, 2011 | 03:19 PM
southsidecox's Avatar
ive got a cloyes adjustable timing gear and the eccentric bolt cam that came with my long block when i bought it,contact me if you want to buy cause i could care less about dealing with adj. setup,was about toi put it up for sale on here,i have the orig. box it came in too,i think that it with an ls2 timing chain would be good setup
Old Mar 5, 2011 | 03:20 PM
oh,nvm isee your just looking for one that has clearance
Old Mar 5, 2011 | 04:24 PM
GTO1_OHIO's Avatar
I also had no problems with my rollmaster double
Old Mar 6, 2011 | 02:04 AM
ls1 1990 VN's Avatar
Nor did i till it broke!
