243 head questions..
Old Mar 5, 2011 | 07:49 PM
408Maro's Avatar
Default 243 head questions..
Hey everyone so I just picked up a set of non sodium filled valved 243s and had a few Qs..I'm running a stock block with most likely a eps cam which id like to get specd around the same as a cheaTR v3 which is 219/230 on 117 with around 595/605 lift I believe.
The heads are stock untouched and basically look new I'm going to get bowl work done and was recommended by the machinist to just take off .02....how much should I have taken off and which gaskets should I go with?
Also what valve stem seals should I use? I'm going to swap my prc duals over from my stock heads..
Thanks
Old Mar 5, 2011 | 08:43 PM
xdanny510x's Avatar
mls cometic gaskets! and as far as ur cam goes.! go big or go home like ur boy chevyman says !
Old Mar 5, 2011 | 08:54 PM
h8tulooze's Avatar
I just took off .20 on mine, with a stock gasket you should be at 11 to 1 CR.
Old Mar 5, 2011 | 09:15 PM
408Maro's Avatar
Lol don't need to go big. Been there done that..ok how much can I do with my came then?
Happen to know the part number on stock gasket you used? And what size cam? Thanks
Old Mar 5, 2011 | 10:34 PM
garygnu's Avatar
you are Cali you must need a emission cam?contact Patrick-G on this forum for great power.he will advise you on milling and head gasket thickness.
Old Mar 5, 2011 | 10:44 PM
408Maro's Avatar
Correct. I am planning on going through him or just straight to eps but good point on going through him first and finding out what's best. What about seals?
