Using too much gas...help
Old Feb 16, 2004 | 11:38 AM
Firehawk536's Avatar
Angry Using too much gas...help
Hi all,
I am using about 1/4 tank of gas for a 20 min trip. That is not right. When I visit relatives in Louisville (Which is 1.5 hrs. away), I usually use up about 1/2 tank or less.
Are my cats clogged up? My car is a 2002 T/A Firehawk. Could you all give me ideas on what it could be?
What things do I need to check?
Thanks,
Adam
Old Feb 16, 2004 | 01:09 PM
strokedls1's Avatar
Maybe a bad front driver 02. If the o2's aren't working right it can run rich and use up a lot of extra gas. You need to autotap or scan with efi live to see if anything looks off.
Old Feb 16, 2004 | 02:14 PM
INMY01TA's Avatar
Make sure you got at least 30psi in the tires. Clean air filter helps too.
Old Feb 16, 2004 | 04:40 PM
Thanks guys,
I will do that.
ADAM
Old Feb 16, 2004 | 05:46 PM
z98's Avatar
z98
Use your trip ticker and find out how many MPG you are getting first.
