ls1 running terrible
Old Mar 10, 2011 | 12:54 AM
Greekey's Avatar
Have you screwed with your mass air flow sensor at all prior to cleaning it tonight? Like installed a lid recently? Any work around the maf?
Old Mar 10, 2011 | 12:55 AM
mrdreex's Avatar
None at all. I have done nothing but change the gear oil out on my t56.
Old Mar 10, 2011 | 07:04 AM
mrdreex's Avatar
bump..
Old Mar 10, 2011 | 07:45 AM
Always2Slow's Avatar
I blame the gear oil. Anywways try changing the maf out with another stock one.
Old Mar 10, 2011 | 09:36 AM
mrdreex's Avatar
Only know one other person with an ls1, and his car is in the shop..
bump...
Old Mar 10, 2011 | 12:12 PM
SSCamaro99_3's Avatar
Originally Posted by mrdreex
EDIT: also, I was wrong earlier: there are two o2 sensors in the collectors, one on the passenger side and another on the drivers side. so, that makes 4 plugged in, and 2 missing (cat o2's).
These cars only come with 4 O2's total. 2 before the cat. 1 on each side that monitor the A/F. 2 after the cat. 1 on each side to monitor cat performance.
If you are still running no rear O2's, you will immediately pop a new SES light for no reading from the rear o2's unless it is tuned out.
Old Mar 10, 2011 | 01:32 PM
mrdreex's Avatar
Ok, well, I have them, I was mistaken. I have two, what look like, sensor bungs on both my headers at the front, in the engine compartment. I'm guessing that's for the EGR?
Old Mar 11, 2011 | 08:47 AM
mrdreex's Avatar
Well, I fixed it last night. ENG SEN fuse was blown, go figure. Did not notice it last night when I was resetting the PCM.
Old Mar 11, 2011 | 04:47 PM
nik1703's Avatar
Nice. good job.
