Opinions on DCR and SCR
Old Mar 13, 2011 | 07:24 PM
speedtigger's Avatar
Old School Heavy
Here are a couple static and dynamic compression work ups. One for an LS6 as a benchmark test to confirm that accuracy of all data. We know that with these ls6 specs, we should get 10.5:1 and we do. Then we only change the head volume and we get 11:1 static with an 8.5 dynamic. I have confidence in these numbers. So, this should be your actual numbers with your 60.5cc heads.
Attached Thumbnails Opinions on DCR and SCR-ls6-compression.jpg   Opinions on DCR and SCR-milled-head-compression.jpg
Old Mar 13, 2011 | 07:43 PM
intenseblue's Avatar
I would like to hear more on this. Try exactly what you did with 0 for piston volume and .058 thickness gasket and you'll find a 10.494 SCR
Old Mar 13, 2011 | 07:48 PM
Old School Heavy
I don't want to confuse the issue anymore. I am using the specs for a stock head gasket. I also don't want to use "0" for the piston volume because that is just not correct. Even a perfect flat top piston has some volume because of the area above the rings. This is a nice way that the OP can see what his actual compression with the cylinder heads he wants to use.
Old Mar 13, 2011 | 07:52 PM
I wasn't trying to argue if I came across that way. Just keeping open. Where do you get the specs for the stock head gasket?
Old Mar 13, 2011 | 08:00 PM
mamead's Avatar
Hmmmm... I feel like you are confusing me though. I'm using the numbers posted in J-Rod's thread: https://ls1tech.com/forums/generatio...learances.html
Where are you getting 1.4 cc's for the piston? I have stock pistons with no valve relief. Are you estimating the volume in between the tapered section of the rings and bore? I've never seen anyone add that in.
Also, where did you get the head gasket bore to be 3.94? This is what I have: http://sdparts.com/details/gm-perfor...parts/12498544 I've always heard 3.910
Old Mar 13, 2011 | 08:09 PM
araber89's Avatar
From: Holmes County (thats right Amish Country), OHIO
With the numbers you gave i calculated the SCR to be 10.82, not sure where your getting 11.
Old Mar 13, 2011 | 08:16 PM
Which calculator did you use?
Old Mar 13, 2011 | 08:17 PM
Also, where did you get the head gasket bore to be 3.94? This is what I have: http://sdparts.com/details/gm-perfor...parts/12498544 I've always heard 3.900
According to TSP's website the gasket bore is 3.91
Old Mar 13, 2011 | 08:24 PM
mamead's Avatar
That's what I meant, I fixed it.
Old Mar 13, 2011 | 08:38 PM
Samer's Avatar
Ooops..... Sorry, just a typo....
Old Mar 13, 2011 | 08:45 PM
Old School Heavy
This is the compression calculator that I used:
http://www.kb-silvolite.com/calc.php?action=comp
As far as the head gasket bore goes, sorry, i guestimated.
However, if you take anything away from this, it is that you need to have a benchmark to check your numbers. Use the LS6 numbers because you know the compression ratio is 10.5:1. Once you have all your known numbers in the calculator for the LS6 with a head volume of 64.43 to come up with 10.5:1, then you can change the head volume only to 60.5 and you will know the correct numbers.
You would do best not to compare different compression ratio calculators because some calculators may attempt to figure in piston volume above the rings while others do not. The calculator link above does not try to figure that in. So, you will have to supply it. And, since you do not know that number, you will have to use the LS6 benchmark to work backwards and figure it out.
Old Mar 13, 2011 | 09:01 PM
  #32
mamead's Avatar
I guess that makes sense. The only though is when I am reading what other people are running as SCR and DCR, I don't think they are taking those into account for their calculations. I understand what you mean though but if I am going to compare against others, I have to use the same method as theirs I guess. I'm going to run it and like someone mentioned before, full up on 91 when I go for my tune. I'll try to run 93 whenever possible but won't have to worry too much if the gas station only has 91. I'll post up my results after the tune.
Old Mar 13, 2011 | 09:02 PM
  #33
Old School Heavy
Here is an article that talks about not forgetting the piston volume around the ring area:
http://www.chevyhiperformance.com/te...ide/index.html
Here is the excerpt that applies:
Speaking of accuracy, there is another small volume that is usually ignored but also contributes to compression. This is called the crevice volume and is the tiny volume between the compression ring and the top of the piston. Typically this will not increase total volume by more than 1 cc, but if you’re looking for complete accuracy, it should be included. The best way to account for crevice volume is to measure the entire piston/cylinder assembly with the engine assembled. Using a flat plastic plate with a hole drilled in the top, you can place the piston ½ inch down the cylinder and then fill that volume from a measured burette. Then compare the volume of a perfect cylinder to the amount you measured. The difference will be the combination of any piston top valve reliefs and the crevice volume.
While they make the general statement that it probably not be more than 1cc. You may see it between 1 and 2cc on some pistons. Most guys probably aren't aware of the above unless they spent time in a machine shop.
Old Mar 13, 2011 | 09:12 PM
  #34
mamead's Avatar
Right. That is an excellent point. I never considered it.
Old Mar 13, 2011 | 10:52 PM
  #35
Higgs Boson's Avatar
My DCR is calculated at 8.606 and I run 93 all the time. It doesn't take a whole lot of spark timing though; 17-19 degrees in the 4600 RPM area. I can get nutty with some C12 though.
