What if Dot-Dot was off by a tooth?
Old Feb 17, 2004 | 02:02 PM
v8maro's Avatar
i'm curious what 2 cams are in question also
Old Feb 17, 2004 | 02:08 PM
Tally TransAm's Avatar
how are you gonna ask why are my old cam and new cam peaks at the same spot when you wont even post the specs???
Old Feb 17, 2004 | 02:26 PM
KGSloan's Avatar
it would be easier to help you if we knew what you had
otherwise we're just shooting in the dark
Old Feb 17, 2004 | 03:51 PM
BLKWS6's Avatar
Sorry bout that...224/230 .560ish to a 228/230 600ish....both 112+4* and also a ASP pulley with the new cam....
Old Feb 17, 2004 | 03:56 PM
Jim98TA's Avatar
I am no expert by any means, but with the similar specs of those cams, I wouldn't really expect much difference. The similar durations and lobe separations are going to keep the power range in the same RPMS. The extra lift would be helpful if your heads had strong flow up to .600 or more, but even that is not a HUGE difference. This is all just my .02 worth...
