Headgasket question
Old Mar 19, 2011 | 09:29 PM
1badeagle's Avatar
Default Headgasket question
Hey guys,
I have a 03 lq4 with 58cc heads and want to run a cam bigger than a 224. Can I run a thicker headgasket than .051? Who makes the head gasket? Where can I get them?
Please help if you can..
Dustin
Old Mar 20, 2011 | 03:59 AM
cbr600rx7's Avatar
You could get a set of Cometic MLS gaskets and they range from .040 to .060 depending on what you want. Not sure why you are trying to go down on your CR if you plan on running a bigger cam
Old Mar 20, 2011 | 09:05 AM
1badeagle's Avatar
I'm trying to add clearance back since my heads have naan milled.
Old Mar 20, 2011 | 09:11 AM
dmelvin's Avatar
Speed Engineering has Cometic gaskets from .027 to .120 thickness.
Old Mar 20, 2011 | 10:29 AM
1badeagle's Avatar
Does my idea make since to run a thicker gasket?
