Fixing Stripped Crank?
Old Mar 22, 2011 | 01:53 PM
Gun5's Avatar
Default Fixing Stripped Crank?
Well I got a 01 T/A with a 383 stroker motor in it (Supposidly) either way it was a good deal... but the crank is stripped except for maybe half a inch at the end.. now I remember using a helicoil a long time ago on a LT1 I had with bad threads what do you guys recommend here?
and the crank is a scat crank..... can u tell from just the snout by any chance?
Old Mar 23, 2011 | 10:17 AM
Isolde's Avatar
My LQ4 crank has bad threads, I'm definitely going to heli-coil it. But I'm also gonna get stupid and install the damper with the cave-man tool, so I won't stress the heli-coil. The correct damper-installation tool might over-stress the fresh repair.
However, I'll be doing this before buttoning up the engine, because I want to make sure I don't hurt the thrust bearing or anything.
Old Mar 23, 2011 | 12:17 PM
RARON455's Avatar
I am not sure if a helicoil can hold the torque that thecrank bolt specs to. You may need to just re tap it, You state that they are good 1/2 inch from the end, Do you mean the balancer side or the engine side of the hole? ALSO ISLODE,,,I hope by caveman tool you dont mean a hammer,,Installing your balancer with a hammer can cause serious damage to your engine.
Old Mar 23, 2011 | 01:36 PM
Gun5's Avatar
at the end is where the threads are
Old Mar 23, 2011 | 01:55 PM
RARON455's Avatar
they go fairly deep into the snout, are you saying that it threads in a few turns and stops, or that you cant get the bolt to grab unless its way in the snout.
Old Mar 23, 2011 | 02:55 PM
Gun5's Avatar
oh sorry.. it grabs just over half a inch all the way in.. i marked it and measured
Old Mar 24, 2011 | 09:45 AM
Isolde's Avatar
If only the first half inch of threads are bad, that typically suggests someone tried to pull a damper on using the original bolt.
