Head and head gasket ?s ...
Old Mar 22, 2011 | 05:47 PM
1Psycho's Avatar
Default Head and head gasket ?s ...
Starting to get parts for my cam swap with heads/intake upgrade. The engine is a stock 98 ls1 with 130k on it, I'm doing all the supporting mods (valve springs, timing chain, pushrods, oil pump) and I'm gonna do ls7 lifters while I have the heads off as well. My first question: is it worth it to go with 243 heads over 241's with that? I won't have them ported for awhile and either way its an upgrade from the stock crappy 806? heads I believe they are, just wondering if it's worth the $200 difference. My next question: what size head gaskets should I go with? Want to bump up the compression a little bit but nothing too crazy on this engine.
Old Mar 23, 2011 | 12:27 AM
1Psycho's Avatar
nothing?
Old Mar 23, 2011 | 08:24 AM
Jon@Texas-Speed's Avatar
Definitely worth it to go 243s. It's a better head that has more potential down the road.
On gaskets, I wouldn't mess with Cometics on what you are doing. If you stay with the 806 castings, you need to run the GM graphite gaskets. If you change to a 241 or 243, I would put on a set of GM MLS gaskets. We have both on the shelf.
Let me know if you have any other questions!
Jon
Old Mar 23, 2011 | 08:40 AM
1Psycho's Avatar
Thanks Jon! PM sent
Old Mar 23, 2011 | 09:09 AM
bigboykilroy's Avatar
I have a 98, when i did my upgrade, I got a set of 243's and had TEA CNC port them for me, then used the GM MLS gaskets, been very happy.
