Oil Temp Sender Location?
Old Mar 23, 2011 | 09:37 PM
MTBSully's Avatar
Default Oil Temp Sender Location?
This might not be the right place for this but whatever. I have an autometer oil temp guauge laying around so i figure i might as well install it. I have heard you drill and tap in a spot above the oil filter but im not sure exactly where this is? Does anyone have more details? (Size of drill bit needed, tap needed ect). IIRC it is a pipe thread right? Thanks guys
Old Mar 24, 2011 | 08:06 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
On the F cars it is the block off above the oil filter, it's got two 10mm bolts holding in on. On the Corvette's this is tapped and where the oil temp sensor is. You can either tap the one you have or find one off a vette
