LS1 block VS. LQ9 block,
Milling the 317s with ls2 head gaskets and installing the trex will result in a significant improvement over the ls1
Build the lq9 with lower miles and parts you have now. Or throw the 243s on the lq9 if it has no heads. I would never take a ls1 over a lq9
But that's just me
And even better in a lq9
Trex pulls hard on top and it's psycho on spray
I shifted mine at 7000 and have hit it with 200 dose
One of my all time fave off the shelf cams. Built many engines with it and recommend it always to anyone who asks
My carb lq4 with 243 heads trex, Vic jr 750 carb and th350 with 4k stall went 10.6 n/a out the gate
More CI and can run higher scr. 364ci uses up the heads more than 346 and it's very noticeable. I've found the trex really works well with higher scr and ci
It alredy has a version of 243 heads
317 use same intake/exhaust ports and valves as 243s
Just larger chambers
A slight mill with thinner ls2 gaskets will raise scr and improve quench
Although since it has flat top pistons, ptv must be verified with cam used. Which may result in having to cut in valve relieves in the pistons for adequate ptv clearance
