max bore on 5.3?
Old Jun 4, 2011 | 06:14 PM
Bilster's Avatar
Originally Posted by defrag010
Bilster, what kind of ultrasonic tester are you using and where are you checking? How are you calibrating it? I ask, because you didn't clarify whether your results were for overall thickness of the whole cylinder (alum + iron sleeve) or just the iron sleeve. I, personally, get wacky numbers with mine when trying to sonic test ferrous metal that is press fit into aluminum..
Sorry for the late reply. I should subscribe to threads I participate in. Anyway....I don't do the actual sonic testing. I have a machine shop that specializes in racing engines do it for me. I've actually never witnessed the operation. I just get a thumbs up or down. I'll call and find out the particulars.
Old Aug 2, 2011 | 05:08 PM
bradw18's Avatar
how many people have done the 5.3 bored to a 5.7? any body got an average wall thickness of a 5.3? iv done got 200 in machine work already and machine shop is saying it cant be done...... its a 1999 cast iron block.. lm7
Old Aug 3, 2011 | 02:38 PM
chrisfrost's Avatar
There's a thread in this section from 2 or 3 months ago that the op talks about boring a 5.3 to the 6.0 bore and sonic checking it and he claims that the 5.3 at the 6.0 bore still is thicker than a gen1 350's walls . I would'nt do it but 5.7 for sure I would do .
Old Aug 3, 2011 | 03:46 PM
kkslds's Avatar
__________________
Thats actually post #9 of this thread
Old Aug 3, 2011 | 11:05 PM
95ONE's Avatar
I bored my 2005 L33 5.3 liter HO block out to 3.898 a few weeks ago. Checked out great. looks great. Has all the advantages of an LS6 block as described in the earlier posts. Whole motor only cost me $705 complete. I just paid $300 for cleaning, boring with a torque plate, and cam bearings though. Still.. One helluva deal. I have much more money going into it though. NOT a forged bottom end. LS6 pistons and rods. ARP rod bolts. Rods honed after. Double roller and the list goes on. MS4 cam just went in. 243 heads CAME WITH THE MOTOR STOCK. weaker valvetrain than the LS6 though.
Old May 14, 2018 | 11:12 PM
John Gravelle's Avatar
Default Adding ci
it is my understanding that on an aluminum block you can bore it up to be a 5.7 and on the cast iron blocks you can go all the way to 6.0 and still have plenty of meat to run boost
Old May 15, 2018 | 09:16 AM
pantera_efi's Avatar
Default GEN-IV AL BORE @ 98mm
Hi John, many here in CA./NV. use the GEN-IV AL crankcase for off road racing AFTER Sleeves are installed.
My observation, AFTER SONIC, is a MAX BORE of 98mm as common without sleeves.
I ALSO install my 4.1" forged crankshaft/forged rods/forged pistons in the crankcase. (LS-383)
Lance
Old May 15, 2018 | 11:56 AM
00pooterSS's Avatar
Thanks John, but they knew more than that 7 years ago when this thread was active.
Old Nov 23, 2018 | 11:21 PM
10(SS)SILVERSUFER's Avatar
Default 6.2 heads on a 5.3
Wondering if a 5.3 can stand a 4.000 bore with either a turbo or pro charger I have 6.2 heads. Blew the bottom end of my stock 6.2 after doing work to the top end and want to build something stronger
Old Nov 23, 2018 | 11:37 PM
Mavn's Avatar
"I MAID THEESE"
No just no. Plus this thread us 8 years old
