Ptv with comp cam
Old Mar 29, 2011 | 10:58 PM
01TA N20's Avatar
Default Ptv with comp cam
Hey guys I'm wondering if anyone is running comp cam number 54-459-11? The specs are 231/239 .617/.624 113LSA. I am putting a set of brand new AFR heads with 66cc chambers on a stock bottom end and was wondering if I am gonna have ptv issues with this cam. Any input would be greatly appreciated.
Old Mar 30, 2011 | 06:37 AM
vettenuts's Avatar
Since this is your first post, I would suggest sending a PM to Tony Mamo who is on this forum and also is the designer of those heads. I am thinking that since the AFR's have a better valve drop then the stock heads you will be OK but Tony would know. Also, your exhaust duration split from intake is pretty big, which the AFR heads may not respond well to. You may want to run that by Tony as well for his suggestions.
