Gaskets required for head/cam swap?
GM LS1 Cylinder Head Gaskets (left and right side,)
GM Intake Manifold Gasket Set,
GM Exhaust Manifold Gaskets,
GM EGR Gaskets,
GM Valve Cover Gaskets,
GM Vapor Vent Pipe Seals,
GM Water Pump Gaskets,
GM Front Cover Seal,
GM Front Cover Gasket,
GM EGR Seals,
GM Harmonic Balancer Bolt
I also plan to grab some ARP Head studs. My question is are all of these necessary, in particular, the EGR seals/gaskets. Anything else i should be considering for installation? Already have pushrods, assembled heads, cam, oil pump, timing chain, lifters(reason for installation).
Thanks for any input given.
