Battle of the big cam
Old Mar 30, 2011 | 08:46 PM
pozesd99''s Avatar
Default Battle of the big cam
which cam would you guys choose for the baddest biggest cam, that can go into a 346 that can rev to 7k rpms.
and why do you chose it
Old Mar 30, 2011 | 08:48 PM
msydow's Avatar
loved my MS4 with 4.10's of course. made GREAT power up top. had stock rod bolts so the limiter was set at 7200 if i remember right. what you got now?
Old Mar 30, 2011 | 08:54 PM
lusting4ls1's Avatar
i have no experiences myself, but from a lot the threads i have gone throught it seems like the ms3 and ms4 as mentioned above are a couple of the favorites. i have never seen anyone say anything bad about the Trex cam either. even seen PatrickG talk good about the ol trex cam.
Old Mar 30, 2011 | 09:00 PM
pozesd99''s Avatar
well im changing my set up to a more radical one. still on stock heads right now im on a 230/228 .603/.589 110 lsa.
im thinking either ms4 or the trex camshaft.
does the ms4 require flycutting pistons?
Old Mar 30, 2011 | 09:01 PM
Zmg00camaross's Avatar
TREX, Reason, Its the Cam only king. And that is proven. But I am going to get a EPS cam one of his larger spec cams and I should do well. But Geoff at EPS design the TREX so I have heard of a TREX killer but you would have to call him and ask.
Old Mar 30, 2011 | 09:12 PM
pozesd99''s Avatar
any of these require flycutting??
seems like they don't
Old Mar 30, 2011 | 09:14 PM
White Shadow's Avatar
Stock Casting Heads? T-REX
Aftermarket Heads? Vindicator
Old Mar 30, 2011 | 09:16 PM
1Psycho's Avatar
Something like that would probably require a little, just have to measure and see. Some people get away without it but from what I've heard, most have to with a bigger cam. If you want something huge and gnarly, call up EPS, they have the best lobes out right now and have been making wicked power/torque with their custom grinds. I saw a guy that went 450/426 on an 01 camaro, longtubes, ls6 manifold, supporting mods, basic slightly home ported 241s, and a tune with their off the shelf 234/246 111lsa cam.
Old Mar 30, 2011 | 09:39 PM
pozesd99''s Avatar
now does that eps cam require flycutting??
i was just looking at that cam lol
thats the "trex killer"
Old Mar 30, 2011 | 10:01 PM
HMM interesting that mite be the cam I was looking at
Old Mar 31, 2011 | 05:43 AM
BOBS99SS's Avatar
Captain Double Post
I run a ms4,didn't have to fly cut,big cams will be a dog down low,4.10s made the ms4,and with the new rear soon to come I will run 4.30s,with a 150 shot,if I wasn't spraying,I would run a 4.56,I also agree that the eps lobes are great,
Old Mar 31, 2011 | 05:48 AM
MYSTIC-1SC's Avatar
MS3 or MS4 from Texas Speed.
Old Mar 31, 2011 | 08:47 AM
98Aggie's Avatar
Moderator
Check out the mosnter cam that Coach is running. forget the specs but it is in the 250 with .700 lift. he just trap 133.xxx in bad air.
Patrick G has the car idling nicely
Old Mar 31, 2011 | 09:33 AM
Shockwave179's Avatar
TREX is proven.
FTI Hellion is another one though.
243/247 .629/.629 - 112LSA
C5 - 347 forged shortblock - AFR 205 heads - LG headers - over 500 RWHP
2005 GTO - 364 stock shortblock - ETP 225 - Kooks Headers - FAST - 513 RWHP
Old Mar 31, 2011 | 05:14 PM
1Psycho's Avatar
Not sure on that one but I think its right on the edge of either needing a little or not needing it. Call em up and see. Haha, good cam to look at or just get a custom one grind by them for what you want. I just picked up a custom EPS thats just a hair smaller than that one and the guy who had it first (only has 1k miles on it) made 406/398 to the wheels cam only with 3 bad piston rings so I'm hoping I can get some real good numbers from it with 243s and a solid engine haha.
Old Mar 31, 2011 | 05:24 PM
garygnu's Avatar
what rod bolts you got?
Old Mar 31, 2011 | 05:43 PM
kidcamaro98's Avatar
ms3 here...Love it.
Old Mar 31, 2011 | 05:54 PM
Minshall's Avatar
LG Motorsports G5X4 here.
Old Mar 31, 2011 | 06:47 PM
bww3588's Avatar
stock rod bolts and your limiter was 7200? thats just asking for disaster. generally anything over 6500 is reserved for stronger rod bolts. and there is no need to rev an MS4 to 7200 RPM. it makes power untill about 6500. i had my limiter set at 7200 with ARP bolts and shifted at 6900 ish...
Old Mar 31, 2011 | 08:22 PM
huh? my ms3 makes power to 7k. It lost 1hp from 6500-7k.
I can imagine its big brother is the same way.
