Rocker Clearance Q
Now, I currently see 3 possible solutions and wanted opinions.
1. I grind down lightly on the heads where the adjustable studs are to give it clearance (it could weaken the rockers).
2. I remove my heads and grind down on the inside to give clearance for the rockers (it would increase the chances of oil leaks) It would also require work on the valve covers for clearance.
3. I try to return them to the seller here on the boards.
I'm considering choice one if the strong opinion is that enough material won't be removed to weaken it significantly. I know some rockers need clearancing under the nose for spring spacing, but wanted other views or possible other solutions. Thanks
D
Google the Crane rocker arm installation instructions. They have very similar contact with the older perimeter style heads. They have instructions on how to correct the problem.
Do not grind the rockers, period.
Again, thanks.
Again, thanks.
