Single vs. Double Timing Chain Install
Old Feb 18, 2004 | 10:58 PM
Johnny5's Avatar
Default Single vs. Double Timing Chain Install
Assuming that I was going to put a single/double chain in during a cam install would one be more difficult to install over the other?
I have noticed that with a pulley (which I do not have) there is milling and/or shimming going on for a double timing chain. Do they give you all the parts necessary?
The fact that I haven't seen this install on ls1howto or install university freaks me out because I need pictures to understand all this stuff.
Old Feb 18, 2004 | 11:26 PM
Beast96Z's Avatar
In 99% of the cases, you only have to have it machined if you have a vette. The F-bodies have been fine with the pully/double chain issue.
Old Feb 19, 2004 | 04:15 AM
jrp's Avatar
jrp
SN95 Director
i have a rollmaster double timing chain and an un-machined asp pulley and have no problems. the installation wasnt that hard, just uses the 3-arm pulley puller and set it up for 2-arms and gently used it to pull the stock crank snout off.
Old Feb 19, 2004 | 03:08 PM
Spinmonster's Avatar
I have the rollmaster also and it fits with no milling with the UPulley
Old Feb 19, 2004 | 05:44 PM
Ferocity02's Avatar
Double Roller goes in just fine, only thing that needs to be shimmed is the oil pump, and the timing set should come with spacers to do this.
