valve? for a 5.3l
Old Apr 5, 2011 | 09:20 PM
lt56026's Avatar
Default valve? for a 5.3l
I'm building a 5.3l. Want too know what size valves I should get. I have a livernois 232/232 cam stock heads. Looking for ls6 intake when I get the cash.
Old Apr 7, 2011 | 04:12 PM
lt56026's Avatar
Any suggestions
Old Apr 7, 2011 | 05:13 PM
disc0monkey's Avatar
all you want is ls1 or ls6 intake valves your exhaust valves flow better than early ls1 valves
Old Apr 8, 2011 | 02:30 AM
lt56026's Avatar
thank you for the help didn't know that about the exhaust valves
Old Apr 8, 2011 | 09:01 AM
the valve bowls on the intake must be within a certain percentage of the size of the valve too, in other words if you increase the valve by x the bowl needs the same % increase
Old Apr 8, 2011 | 10:24 PM
lt56026's Avatar
that is good to know i'm planning on taken the heads into a machine shop to get cleaned up and flattened anyways but thank you for all the good info
