Will it be safe ???
Old Apr 7, 2011 | 10:00 AM
brett walker's Avatar
Default Will it be safe ???
I have a 2000 z28 m6 that I plan on doing a cam swap on hopefully next week, but before i do so I need some input on my cam/springs setup. I have the Lg G5X2 cam specs are - 112 LSA, 232/240 Duration, 595/608 Lift and the springs that i found for a steel are PSI beehives which support up to .625 lift. I really need to know will these springs be ok to run with that cam ? Heres the link for the springs http://www.usaperform.com/valve-spri...ift-p-969.html
Old Apr 7, 2011 | 10:06 AM
kinglt-1's Avatar
Those should work fine imo...
Old Apr 7, 2011 | 11:01 AM
nichoms's Avatar
I'd prefer dual springs but those should work fine.
Old Apr 7, 2011 | 11:32 AM
Thanks guys. I would go with duals buy i'm on a budget build and found these beehives really cheap.
