THIS is my plan
Old Feb 19, 2004 | 04:00 PM
silverTA's Avatar
Default THIS is my plan
i planning of using a stock 6 liter short block and stage 2 5.7 heads and 228,234/609./598 at 110 lsa
i already got the heads and cam ,,am thinking to spary 200 shot on this
what u all think.
i need to get my car back on the road,,and i don't wanna spend alot of money
Old Feb 19, 2004 | 09:19 PM
Slow Z28's Avatar
i think i remember having to use the stock 5.7L crank in the motor to make it work. won't work with the 6.0L crank
Chris
Old Feb 20, 2004 | 03:38 PM
BLK02WS6's Avatar
Stock 6.0L crank will work as long as it is 2001 or newer. I don't know about a 200 shot on a stock bottom end! I had mine built for a 200 shot, but it has forged rods and pistons. Might not be back on the road long with stock rods and pistons. Just my 2 cents.
Think about it - a 364 cu in with that cam and stage 2 heads ought to be at least 425 rwhp - then you wanna put a 200 shot on top of that - you're braver than I am!
Old Feb 21, 2004 | 01:45 AM
silverTA's Avatar
also i think i need to do some work for the heads to get them to work with the 6 liter??? the heads milled 30 and they fly cut the piston when they installed the H/C in my stock short block so do i need to fly cut the piston in the 6 liter
Old Feb 21, 2004 | 07:02 AM
BLK02WS6's Avatar
I would think you would have to flycut - all dimensions should be the same. Radius the chambers as well.
Old Feb 22, 2004 | 01:41 AM
silverTA's Avatar
thanx
