New setup running well!!!
Old Feb 20, 2004 | 12:08 AM
JS's Avatar
JS
Default New setup running well!!!
I finally got my car together thanks to Jay Fisher Pontiac.He had Cunningham Racing Engines,NJ (NHRA PS Engine Builders) do the shortblock for me.Its a basic rebuild,Nothing fancy....
Stock Crank,Piston,rods...
All GM bolts except ARP Rod bolts
All GM gaskets excpect I used cometic head gaskets
Balance and fit with FM bearing and file fit rings.
Ported oil pump and duel roller
Thats it!!
Cartek newest REVIII head is on my car.
Cartek REV I Cam(I'm NOT using the REVIII CAM at this time)
Specs: 224-224 580-580 113LSA+0 straight up. (Little Cam)
LS6 Intake ported by Julio
PTB from Rapid
The enging PURRS at 900 in gear with NO SUREGE or HUNTING
I need to tune it but Cartek is gonna be away for another 5 days so I wont be able to get it up there til next Sat.I have alot of little things to do like fix a H/L controller,setup the susp. and basically make things alittle neater under the hood along with a catch can to my TB/PCV,braided trans lines.
I'll report back with my final numbers but I'll tell ya the motor is awesome
It has 80 miles on it now and just runs its *** off,I havent taken it over 4500 but it pulls hard,idles nice with a very slight lope,(stealthy almost) and then roars to life when u hit the throttle.Oil Psi is a perfect 45 at idle going up to about 70 under rpm.
Thanks to Jay Fisher/Cunnigham Racing Engines and most of all Cartek for there badass S2X Package.I'll be at Atco come March 6th beating the bag out of the car,U can be sure of that boys...
Hoping to finally see the 10's???
Old Feb 20, 2004 | 12:37 AM
Jantzer98SS's Avatar
Maybe with that hidden 100 shot.
Old Feb 20, 2004 | 12:57 AM
JS's Avatar
JS
Jan its actually a 150 shot but at least I dont brag about running 10;s in a f-body the weight of a civic
Its all good,Hope all is well..
Old Feb 20, 2004 | 03:13 AM
Well I hope you can make it JS. I would really like to see you runs 10's.....after 6 h/c swaps. Actually I was running 10.9's at 3250lb raceweight in 2000ft DA's when I put a bunch of stuff back in the car like a stereo, headlights, ya know the stuff you don't need.
Old Feb 20, 2004 | 08:41 AM
JS's Avatar
JS
The day I take my H/L out of the car is the day I end up in the nut house
Keepem comming,I can take it
Whats up with your car,Going vette perhaps?
Old Feb 20, 2004 | 08:51 AM
CHRISPY's Avatar
Congrats!
Good luck in the hunt for the 10 second timeslip!
Are you staying with that small cam?
Old Feb 20, 2004 | 09:10 AM
JS's Avatar
JS
I think so Chris,getting bored of hardcore drag racing....
I'm gonna go to more of a street type setup come the summer...
VIG 3200 + 17's or 18's and DR's for me Frosty
Thanks buddy...
