new heads/ valve spring broke.
Old Apr 24, 2011 | 09:48 AM
LT1SS's Avatar
Originally Posted by vettenuts
That's what I am struggling with, not sure how that could happen. Were any of the piston exceptionally clean? Where was the leak, to the outside of the head or into a cylinder?
If you can't sort this out, you may want to put a machinest's straight edge across the block and the heads and check for flatness. How is the surface finish?
all the pistons looked pretty much the same. we didnt check for flatness. the leak was coming from in front of the number 2 at the bottom corner of the head. we used scotchbrite pads to clean the deck surface.
Attached Thumbnails new heads/ valve spring broke.-head.jpg
Old Apr 24, 2011 | 09:51 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Not sure how you ended up with a blown head gasket, are you sure the surfaces were well prepped? don't worry at all about the spring, we can zip you out a replacement spring in no time flat! We've had great luck with the new v2 of the .675" spring. My bet is somehow that one must have just been goofy from the start.
Call us Monday and I'll make sure we get you a new one to get you guys back in high gear!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 24, 2011 | 10:17 AM
LT1SS's Avatar
im pretty sure we prepped the deck properly. we scrubbed the surface till it looked new. i think that were gonna have to send the head back to be looked at i wanna make sure that the valve guide and seat are still good. the valve stem is bent too. is that possible?
Old Apr 24, 2011 | 10:30 AM
A.R. Shale Targa's Avatar
Probably just a bum spring....I'm sure TSP will make it right....good people
over there !! Thankfully you were running duals so you only need to clean
up(dubur) the piston instead of searching for a replacement shortblock.
The head gasket issue is wierd though....is it possible that although the deck
surface was clean perhaps some coolant was still in the bottom and gave a
false torque on that one bolt ????
Hope it all works out....sounds like a beast of a combo
Old Apr 24, 2011 | 11:14 AM
LT1SS's Avatar
i guess that it is possible but i blew all bolt holes out and chased all threads multiple times.
its a pretty good combo. we raced a c6 with intake and exhaust 35-120 and pulled about 2 cars on him. were looking to get an ls6 intake and do a little more tuning and then it will be a lot better
Old Apr 24, 2011 | 04:20 PM
xpensivehabit's Avatar
i think this is what happened....looking at the gasket it is not damaged in any way, and there was only a little bit of coolant dripping from the one corner....the car itself does not have any coolant in the oil.
Texas Speed has always taken care of me, i am goingto call them monday and see what I need to do to get the car back on the road
Old Apr 25, 2011 | 04:08 PM
I sent an email to Jason and Matt.... Thank you guys for the help
