Piston diameter lq4
Old Apr 25, 2011 | 09:17 PM
Abuckeye's Avatar
Default Piston diameter lq4
Does anybody know the actual measurement of the piston diameter ?
Old Apr 25, 2011 | 09:34 PM
Abuckeye's Avatar
Sorry forgot to put the rest. Does anybody know the actual piston diameter on a 4.00 bore stock piston. Lq4.
Old Apr 25, 2011 | 10:09 PM
bayer-z28's Avatar
I'll see what I can find for ya.
Off an 04 Tahoe 2wd.
Metric
English
General
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LQ4
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0014 in
Cylinder Bore Diameter
101.618-101.636 mm
4.0007-4.0017 in
Cylinder Bore Taper - Thrust Side
0.018 mm
0.0007 in
Piston - Piston Diameter - Measured Over Skirt Coating
101.606-101.640 mm
4.0002-4.0016 in
Piston - Piston to Bore Clearance - Production ****************
0.022-0.03 mm - interference
0.0009-0.0012 in - interference
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off ************************************************** *******
0.07 mm
0.0028 in
