Lq4/9 6.0 block question
Old Apr 26, 2011 | 08:51 AM
matrixiskool's Avatar
Default Lq4/9 6.0 block question
I'm wondering what year and what model trucks use 6.0 blocks. I'm going to a couple salvage yards to find a 6.0 block. also would help to know what year trucks use the 6.0 blocks that are compatible with 408 builds, I already have the rotating assembly from TSP. thanks
Old Apr 26, 2011 | 09:12 AM
Jon@Texas-Speed's Avatar
It just needs to be a 6.0L block to work with a 408 rotating assembly. I think I would look at '03+ 2500 series GM trucks. Maybe even some 1 ton trucks had them.
Jon
Old Apr 26, 2011 | 10:22 AM
Ok so 2500, thanks. I also emailed matt at your place about my order maybe he is away. Could you take a look at my email thanks.
Old Apr 26, 2011 | 11:02 AM
Slamdsdime's Avatar
It may go without saying, but remember that 2500 trucks include Yukons and Suburbans. My LQ4 came from an '03 Denali.
Old Apr 26, 2011 | 11:46 PM
I understand that thanks, I can't find one of these things freaking anywhere this is so frustrating.
Old Apr 27, 2011 | 09:17 AM
He was out Friday and Monday. Should get back to you shortly. If not, you can forward it to me and I will try to get you fixed up.
Jon
Old Apr 28, 2011 | 06:02 AM
9t8ta's Avatar
Do not buy a 99 or 2000 motor. Crankshaft issues.
Old Apr 28, 2011 | 09:30 AM
With a 408 he'd be replacing the crank anyway. IMO, I would try and find the newer 6.0 block but as long as it's in good shape, you can probably make it work.
Jon
Old Apr 29, 2011 | 06:52 PM
Yeah I dont need the original crank, still looking for one and trying to not have to buy a new one off jeggs or somewhere...
Old May 3, 2011 | 09:24 PM
tatersalad25's Avatar
im not trying to advertise for these guys but check out www.car-part.com its kinda like a salvage yard directory, it has a search option that can narrow down exactly whos got what, what conditon its in and how much they want for it. I used it to locate a 6.0 for my build and ended up finding what I needed for cheap.
Old May 3, 2011 | 10:51 PM
Wildcobra's Avatar
Look at LKQ.com
