cam>>>
Old Apr 26, 2011 | 10:34 PM
bonehead79's Avatar
Default cam>>>
Thinking about putting a cam in a 98 ls1 stock motor its in a 1st gen camaro with a 6 speed with 373s looking to make between 400-450 to the wheels what do i need to do other than a cam,It has long tube headers already and true duals with flowmasters
Old Apr 26, 2011 | 11:34 PM
shorty(98TA)'s Avatar
I just talkd to texas speed about a cam package for my stock ls1 a couple days ago. I ended up going with their torquer V.3 cam package. It would also do your ls1 good the throw on an ls6 intake and ported/polshed TB too. If you go ahead and do the cam swap you should throw on a ported ls6 oil pump and ls2 timing chain at least while you have it tore apart. From all the research Ive done on it they are must have upgrades.
good luck with your build
Old Apr 27, 2011 | 07:06 AM
garygnu's Avatar
parts mentioned above +harden pushrods,new rod bolts,ported heads.
Old Apr 27, 2011 | 11:46 AM
Paul 75 L82's Avatar
Do you really need to replace the rod bolts?
Old Apr 27, 2011 | 06:09 PM
1Psycho's Avatar
Only if you plan on spinning it much past 6500-6600 on the 98s. They came with weaker rod bolts and everyone who spins higher seems to have big problems
