Mods
Old Apr 28, 2011 | 09:35 AM
K98M91's Avatar
Default Mods
So i have a 99 camaro with air bag in the rear shocks, granatelli maf, Holley lid, slp catback exhaust, and im running 12.9 and want a some more umph but im broke so i was wondering what are some free or cheap mods that i could do?
Thanks
Old Apr 28, 2011 | 09:49 AM
brian_rs/ss's Avatar
stock manifolds? you might have the cat's deleted by a local exhaust shop then take it to a tuner and have them tune out the rear o2's, and maybe dyno it while your at it. a tune is always a good place to pick up a few horses if you're still on stock tune.
you could also pick up a ls6 intake for fairly cheap. every now and then you can find one for less than 300 used on here. you could also find a set of used headers/y-pipe for real cheap as well. (don't forget poly motor mounts when doing lt's)
is your car an a4 or m6? if it's a4 look into stalling it, if it's an m6 look into the tick master cylinder and speed bleeder. these things may not give you any more hp but they will get you down the 1/4 more effectively. and are not that expensive.
have you deleted EGR/AIR? that's damn near free.
have you put your ride on a diet yet? there is plenty you can ditch to shead some extra pounds. ie: jack/spare tire, rear seats/belts, sound deadening, misc loose crap, etc etc.
Old Apr 28, 2011 | 09:54 AM
projectX's Avatar
Check out the FREE MOD in the search and choose one or two.
Old Apr 28, 2011 | 10:02 AM
except that most of the "free mods" are a waste of time at best. there are only a few free mods that are worth while. it takes money to make horsepower.
now if you are really serious about bang for your buck then go ahead and order you a 78mm plate system from nitro dave's and have fun.
Old Apr 28, 2011 | 01:52 PM
K98M91's Avatar
Yea i did put it on a diet and shaved some pounds and i did pickup an offroad y-pipe and was planing on a tune.
Old Apr 28, 2011 | 02:02 PM
well then there u go. lt's/y + tune and you should shave some time off. then just keep savin up for the long run.
Old Apr 29, 2011 | 01:17 AM
cowboysfan's Avatar
lower gear on differential. if auto trans go with 3.73 or if manual go with 4.10's. that will get you into the power band quicker which equals quicker ET.
